  • MK 429 posts 906 karma points
    Mar 28, 2012 @ 09:11
    MK
    Fields behaviour
    Hi there,
    For some reason when using the Compare Textbox option the second textbox is not aligned with the first one.
    Now I know I can fix this with simple css but It also gets the following values which looks a bit odds:
    <span>Verify E-mail Address</span>
    <input id="test" type="text" name="test">
    Where does it gets the test value?
    Also, the Dropdownlist does not get a default value and the indexing is wrong. the first value is an empty option tag:
    <option value=""></option>
    Any Idea?
    Many thanks
    mkariti
    Mar 28, 2012 @ 09:27
    MK
    Another thing, when setting workflow for a form such as Save as umbraco document – It asks for a Node name. Is it possible to set this programmatically?
