Well you can extend Contour with your own code so depends a bit what it has to do, does it have to work with the Dotmailer api? You might want to look into creating a custom workflow then that does what you want. To get started take a look at the default workflow code you can find it in the Contour project page
Dotmailer
Hi, Anyone got an idea how I can tie up a Contour form to Dotmailer?
Any help will be hugely appreciated!
Comment author was deleted
http://our.umbraco.org/projects/umbraco-pro/contour (at the bottom source code tab)
