  • S.Bhargava 13 posts 33 karma points
    Apr 12, 2012 @ 09:17
    S.Bhargava
    Umbraco 5.0.1 and Countour 2.0
    Hi all,
    I have installed Umbraco 5.0.1 and have installed Countour 2.0 RC to it from the below link http://nightly.umbraco.org/Umbraco%20Contour/Umbraco5/2.0.0/RC/
    The problem is Countour Form can be seen as a Macro but I cannot see the Countour icon in the settins section,even after restaring the application.I am currently using VWD 2010 .Any suggestions...?
  • Comment author was deleted
    Apr 12, 2012 @ 09:36
    Hey,
    Contour 2.0 RC doesn't support Umbraco 5.0.1, you'll have to install it on 5.1, you can get the latest 5.1 build here: http://nightly.umbraco.org/Jupiter/51/
    Tim
    Apr 12, 2012 @ 09:46
    S.Bhargava
    My bad I saw that in the Countour 2.0 RC page,but forgot about it.Can You please suggest some other Countour RC for 5.0.1 since I need to work with Umbraco 5.0.1.
    Sorry for being dumb :P and Thanks for the quickest reply
    Apr 12, 2012 @ 09:48
    You can use the beta for that
    http://nightly.umbraco.org/Umbraco%20Contour/Umbraco5/2.0.0/Beta/For%20Umbraco%205.0.x/
    (but it's not as stable as the RC)
    Apr 16, 2012 @ 08:48
    S.Bhargava
    Hi Tim
    I have been trying to use Umbraco databse to store the contact information.For that I have created a table named "Contact Info".
    I have created a new datasource named "User Contact Info" in the backoffice and mentioned the following details
    Provider=SQLNCLI10;
    Server=xxxxx;
    Database=Umbracodb;
    Uid=xxxxx;
    Pwd=xxxxx;
    In the above in "Database" I have given the same database name in which the Umbraco CMS is installed.The "Contact Info" table has been also created in the same database.But I get "Please check the settings" message. But when I mention some other database name the datasource gets saved successfully.
    Can you please say what am I doing wrong and how do I store the user info in contact form after he clicks submit
    Edit: Changing the name to "Contact_Info" instead of "Contact Info" solved my problem.Now on clicking submit, the record is also saved in the db, I guess, I am not sure because I cannot see the record due to trial version of contour,but whenever I create a new record manually in the DB I see incremented id of the table which is greater than I expect.Can I not see the records submitted using Countour trial version....?
