  • Guy Pucill 23 posts 73 karma points
    Apr 28, 2012 @ 08:49
    Guy Pucill
    How to upgrade Umbraco that has Contour?
    I have just upgraded to Umbraco v 4.7.2 (Assembly version: 1.0.4500.21031).
    What do i need to do to get
    Apr 28, 2012 @ 08:55
    Guy Pucill
    I need to upgrade to Umbraco v 4.7.2. Which procedure do i need to follow if i have the Contour package installed?
    Apr 28, 2012 @ 09:26
    Guy Pucill
    I have now got everything working in backoffice. I can create new forms and data sources and front-end forms are sending entries. All my original forms are still working and my data is still there.
    My only problem is that i get an "Error parsing XSLT file:".
    My XSLT uses the Contour xslt extension:
    umbraco.contour:GetRecordsFromForm
    This is used to parse data from the Contour XML and into a HTML table that i used front-end to display user entries.
    It was working before the upgrade.
    Apr 28, 2012 @ 09:44
    Guy Pucill
    I tried to output the raw XML
    <textarea><xsl:copy-of select="umbraco.contour:GetRecordsFromForm('3efa868e-39f0-4413-9958-464be958a84c')"/>textarea>
    But could not save the XSLT file because of an error.
    I saw that
    xmlns:umbraco.contour="urn:umbraco.contour"
    was missing in the header, so i wrote it into my XSLT file.
    Then i got:
    Cannot find a script or an extension object associated with namespace 'urn:umbraco.contour'.
    Apr 28, 2012 @ 10:09
    Guy Pucill
    Problem fixed.
    Just needed to add
     <ext assembly="Umbraco.Forms.Core" type="Umbraco.Forms.Library" alias="umbraco.contour"></ext>
    to the xsltExtensions.config file.
    When creating a new XSLT file now, the correct xmlns namespace will be added, at the top of the XSLT file automatically.
