I found something similar as well. I uploaded Contour 2 as a local package and it said "sucessful" but didn't show up as a local package through the UI. I tried a few different things with no success. Then I droped the nuget package into the App_data/Umbraco/LocalPackages and it showed correctly in the interface. So even though it said everything was successful it didn't actually upload it.
From there I was able to enable it and it moved and unpacked it App_Plugins/Packages/Contour and Contour showed in the Sections.
Problem installing Contour 2.0.0 on Umbraco v 5.1
Hi there!
I have tried to install Contour 2.0.0 package both through Umbraco interface and manually.
Results:
Problem:
Thanks in advance!
Do you mean the Contour section doesn't appear in the "Sections" panel? Can you access it using the URL directly, something like this:
Even if this does load the correct parts, it's hardly a solution, but might suffice for the time being until you get proper help.
Comment author was deleted
Yes if there was an issue during installation you can always do a manual install, details on that can be found in the manual installation guide
bottom of the page, documentation tab http://our.umbraco.org/projects/umbraco-pro/contour (installation guide for umbraco 5)
