  • Alessandro Bellisai 30 posts 120 karma points
    May 10, 2012 @ 15:44
    Alessandro Bellisai
    Post form to url not work
    I've some problem when i ty to post the form to a generic handler:
    The follow image show how i've configure contour on the approved step :
    The problem is that seems that post to url not work.
    First question if i set the method to GET, how is composte the request?
    I suppose something like "UrlToPost?email=...&group=consorzioremedia&formUrl=test" is it rigth?
    On the ashx page i've implemented a log to trace the request.
    If i invoke the handler via browser, it write correctly on the log all the information, but when i try to submit the contour form nothing happends, like if countor not call the remote page.
    The contur version is 1.1.6
    Some one can help me?
    Regards
    Alessandro
  • Comment author was deleted
    May 16, 2012 @ 14:34
    The post will happen in the background + make sure that you can access the url on the machine running the site
    May 16, 2012 @ 14:35
    Also check the umbraco log table to see if there are any errors in regards to the workflow execution
    May 16, 2012 @ 22:05
    Alessandro Bellisai
    Hi Tim
    Thankyou for your help, i've double check that the remote url configured in countur was accessible from server, and i found the problem.
  • Vigneshkumar 3 posts 73 karma points notactivated
    Mar 17, 2020 @ 13:43
    Vigneshkumar
    It doesnot work for me.....
