  • Michael Ogilvie 4 posts 24 karma points
    May 14, 2012 @ 22:03
    Michael Ogilvie
    Auto fill address information based on zip/postal code
    How would I achieve this?
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    May 16, 2012 @ 12:20
    Tim
    You'll probably need to use some kind of Postcode lookup service, such as Postcode Anywhere or something similar. They have a javascript API that you can use to get address details when the postcode is filled out and populate the rest of the form. You'll be better off doing it all client side with Contour, as it'll be hard to plug something like that in on the server side.
