I've just been looking at the contour package and it doesn't appear to install on V5.1, is this a known issue thats being looked at? Could only find one post about the issue, which doesn't state if its being looked at.
The current version is Umbraco 4.X only. There is a v5 on in the works (called Courier 2.0). You can grab the betas from the nightly builds server: http://nightly.umbraco.org/Umbraco%20Contour/Umbraco5/2.0.0/ I'm not sure how far it is from final release though. Hope that helps!
Process information: Process ID: 920 Process name: w3wp.exe Account name: IIS APPPOOL\DefaultAppPool
Exception information: Exception type: NullReferenceException Exception message: Object reference not set to an instance of an object. at Umbraco.Cms.Web.Configuration.UmbracoSettings.<get_Trees>b__f(ITree x) at System.Linq.Set`1.InternalGetHashCode(TElement value) at System.Linq.Set`1.Find(TElement value, Boolean add) at System.Linq.Enumerable.<DistinctIterator>d__81`1.MoveNext() at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at Umbraco.Cms.Web.Trees.ApplicationTreeController.Index(String appAlias) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) at Umbraco.Cms.Web.Mvc.ActionInvokers.ControllerExtenderActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) at System.Web.Mvc.Controller.ExecuteCore() at System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) at System.Web.Mvc.MvcHandler.<>c__DisplayClass6.<>c__DisplayClassb.<BeginProcessRequest>b__5() at System.Web.Mvc.Async.AsyncResultWrapper.<>c__DisplayClass1.<MakeVoidDelegate>b__0() at System.Web.Mvc.MvcHandler.<>c__DisplayClasse.<EndProcessRequest>b__d() at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Request information: Request URL: http://ukboliis7/Umbraco/Trees/ApplicationTree/Index/developer?_=1337172143741 Request path: /Umbraco/Trees/ApplicationTree/Index/developer User host address: 192.168.200.173 User: admin Is authenticated: True Authentication Type: Forms Thread account name: IIS APPPOOL\DefaultAppPool
Thread information: Thread ID: 17 Thread account name: IIS APPPOOL\DefaultAppPool Is impersonating: False Stack trace: at Umbraco.Cms.Web.Configuration.UmbracoSettings.<get_Trees>b__f(ITree x) at System.Linq.Set`1.InternalGetHashCode(TElement value) at System.Linq.Set`1.Find(TElement value, Boolean add) at System.Linq.Enumerable.<DistinctIterator>d__81`1.MoveNext() at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at Umbraco.Cms.Web.Trees.ApplicationTreeController.Index(String appAlias) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) at Umbraco.Cms.Web.Mvc.ActionInvokers.ControllerExtenderActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) at System.Web.Mvc.Controller.ExecuteCore() at System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) at System.Web.Mvc.MvcHandler.<>c__DisplayClass6.<>c__DisplayClassb.<BeginProcessRequest>b__5() at System.Web.Mvc.Async.AsyncResultWrapper.<>c__DisplayClass1.<MakeVoidDelegate>b__0() at System.Web.Mvc.MvcHandler.<>c__DisplayClasse.<EndProcessRequest>b__d() at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Custom event details:
The tables do not appear in the database, i am going to try an manually install now
I've installed Contour on a 5.1 site (upgraded from 5.0.1), but I cannot get to grant the admin access to the Contour section. Whenever I check "Contour" to be visible and save the user, the browser waits for the page to respond and eventually I see an IIS error about the connection timing out. I've checked the db, and the Contour tables are there. The stack trace reports an SQL exception.
I've downloaded & installed Contour.2.0.0.nupkg via packages & manually & am getting the same error when I click on the Contour icon in Sections. My login has access & I've tried touching the web.config. Do you know what's wrong? The exception is:
Exception
Error executing child request for handler 'System.Web.Mvc.HttpHandlerUtil+ServerExecuteHttpHandlerAsyncWrapper'.
Inner exception
The type initializer for 'Umbraco.Forms.Data.Helper' threw an exception.
Stack trace
at System.Web.HttpServerUtility.ExecuteInternal(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage, VirtualPath path, VirtualPath filePath, String physPath, Exception error, String queryStringOverride) at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage) at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm) at System.Web.HttpServerUtilityWrapper.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm) at System.Web.Mvc.Html.ChildActionExtensions.ActionHelper(HtmlHelper htmlHelper, String actionName, String controllerName, RouteValueDictionary routeValues, TextWriter textWriter) at System.Web.Mvc.Html.ChildActionExtensions.Action(HtmlHelper htmlHelper, String actionName, String controllerName, RouteValueDictionary routeValues) at Umbraco.Cms.Web.ProxyControllerExtensions.ExecuteProxiedControllerAction[TResult](ControllerBase controller, String proxyControllerName, String action, String area, IEnumerable`1 routeVals) at Umbraco.Cms.Web.ProxyControllerExtensions.ProxyRequestToController[TResult,TControllerType](ControllerBase controller, TControllerType proxyController, Expression`1 methodSelector, String area, IEnumerable`1 routeVals) at Umbraco.Cms.Web.ProxyControllerExtensions.ProxyRequestToController[TResult,TControllerType](ControllerBase controller, TControllerType proxyController, Expression`1 methodSelector, PluginMetadataComposition pluginDef, String backOfficePath, String routeIdParameterName) at Umbraco.Cms.Web.Trees.ApplicationTreeController.GetRootResultFromTreeController(ITree t) at Umbraco.Cms.Web.Trees.ApplicationTreeController.Index(String appAlias) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<>c__DisplayClass17.<InvokeActionMethodWithFilters>b__14() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<>c__DisplayClass17.<InvokeActionMethodWithFilters>b__14() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<>c__DisplayClass17.<InvokeActionMethodWithFilters>b__14() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)
I'm in the same boat as above, a freshly installed Umbraco 5.1 (manual) installation. I uploaded the 2.0 nupkg sucessfully, click install. Message says sucessfull and refreshes, I get the following error immidiately:
Source Error:
Turns out adding NETWORK SERVICE permissions fixed the installation issues. But now I get a different error when licking on the Contour icon in the back office:
Unable to find the requested .Net Framework Data Provider. It may not be installed.
Exception Details: System.ArgumentException: Unable to find the requested .Net Framework Data Provider. It may not be installed.
Source Error:
Adding NETWORK SERVICE didn't help my installation. Using Fiddler I can see that a request is made to Umbraco/Trees/ApplicationTree/Index/contour?_=1337348419941 & this is returning the exception I mentioned in my previous post.
Contour on Umbraco 5.1
John
Hiya,
Hi Tim,
It does appear that contour 2.0 has been release and it only supports v5.1, however the install package doesn't work for us
http://umbraco.com/follow-us/blog-archive/2012/5/3/contour-20-is-out.aspx
Comment author was deleted
Hi John,
Yup Contour for 5.1 is out... can you share some details on what is happening during the installation...
If the package installation fails you can also do a manual install, check out the manual installation guide on the contour project page
If you check your db are there any Contour tables, prefixed with UF
Probably the installation failed to give your current user access so if you update your user you should be able to see the Contour section..
Hi Tim,
I've tried the package install again and the error message i get is
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 16/05/2012 13:42:23
Event time (UTC): 16/05/2012 12:42:23
Event ID: 7a7fad035bae45a0bd36875a248f6283
Event sequence: 298
Event occurrence: 3
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-129816441509380336
Trust level: Full
Application Virtual Path: /
Application Path: C:\Websites\Umbraco51\
Machine name: UKBOLIIS7
Process ID: 920
User: admin
Thread information:
Thread ID: 17
Ok make sure you have the correct 'release version' you can download it on the project page
http://our.umbraco.org/projects/umbraco-pro/contour (at the bottom, the nupkg file)
You might need to touch your web.config after placing the Contour directory in the plugins folder
Thanks Tim, touching the web.config has fixed the issue.
Great let me know if you encounter any other issues
Exception
Inner exception
Stack trace
Source Error:
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
My client's have actually paid for a license and not happy they can't use the product out of the box. Could you advise where I'm goin wrong.
Source Error:
