  • Sergio Granjeiro 2 posts 22 karma points
    May 18, 2012 @ 16:59
    Sergio Granjeiro
    Edit previously submitted information using Contour form
    I am new at Umbraco Contour and I have been searching for a while now and have not found an answer to my problem.
    I have a contour form which I use to submit some information. I have a custom workflow which on submit, saves all my information in a database specified by me.
    What I need now is when a user wants to edit his/her profile, the form is already filled which the data he/she had previously submitted. Allowing them to change what they want without the need to fill out all the information again. I was trying a custom workflow which  would be called on “When the form has been Opened” but nothing seems to happen when I preview the form. I have placed breakpoints to see if the problem might be in the code but it doesen’t even stop. If I place my workflow on “When the form has been Submitted”, the breakpoints are hit…
    Any help would be much appreciated.
    Sergio
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.Data.Storage;
    using Umbraco.Forms.Core.Attributes;
    using Umbraco.Forms.Core.Enums;
    using Umbraco.Framework.Security;
    using System.Web.Security;
    using Umbraco.Cms.Web;
    using Umbraco.Cms.Web.Security;
    namespace ContourV5.ExampleFieldType
        public class LoadRegisterNewEntity : WorkflowType
            [Setting("Something", description = "Something 1", control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string Group { get; set; }
            public LoadRegisterNewEntity()        {
                this.Id = new Guid("4EF14103-2334-42F4-85D2-C426CA2811C8");
                this.Name = "LoadRegisterNewEntity";
                this.Description = "Executes an example workflowtype";
            public override List<Exception> ValidateSettings()        {
                List<Exception> exceptions = new List<Exception>();
                return exceptions;
            public override Umbraco.Forms.Core.Enums.WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
                WorkflowExecutionStatus ret = WorkflowExecutionStatus.Failed;
                switch (e.Form.Name)            {
                    case "Edit Profile":
                        //Do something
                        break;
                return ret;
