Method not found: 'Boolean Umbraco.Licensing.Validator.IsValid()'.
Exception Details: System.MissingMethodException: Method not found: 'Boolean Umbraco.Licensing.Validator.IsValid()'.
Source Error:
I've noticed that too. Apparently the Contour licensing DLL is old and overwrited the newer Courier one on package install. The fix for me has been to reinstall Courier. But this definitely appears like a bug.
After installing and licensing Contour 1.1.12, Courier license gets screwed
Already happened to my 2 times, after installing Contour Courier gives and exception:
Should I file a bug?
Regards
Vlad
Source Error:
