We're running Umbraco 4.7 with Contour and we have a strange and quite annoying issue.
In a multistep form, after filling out fields on step 1, we click "next" and are taken to step 2. If I click the browsers "Back"-button I go back to step 1 but if I then use the "next" button in the form i get the "Failed to load viewstate" error. Is this normal behaviour?
I understand why the error occurs (viewstate is saved in a hidden field and in the db (I think) and after submitting the same page twice, Contour gets very confused) but I think that this kind of behaviour (using the browser's back button) is not uncommon which is why I think this error should be resolved before going public with my forms. Is there any workaround, perhaps?
Hope someone has a solution!
Best regards, Michael
Full error description:
"Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request"
No, and I never pursued the issue when I saw that the link I posted was last updated in 2006. In stead I resolved to enabling custom errors on IIS and made it display a page from Umbraco explaining what to do if the user emcountered this error. I also have a mind to review the error log on IIS to assess if this is even an issue with our users. I just haven't done so yet.
If this indeed is a big issue I know it's possible to disable the viewstate in the master page for the form but this would mean we would have to capture and pass on the contents of the entire form and that means a lot of coding. Which is not the purpose of Contour...
Hi all
Best regards,
Michael
Hi again
After googling "Failed to load viewstate" without "umbraco contour", I found this page: http://www.denisbauer.com/ASPNETControls/DynamicControlsPlaceholder.aspx - which seems to resolve the problem with the viewstate. Does anyone know how to implement this solution in Contour?
Best regards,
Michael
Hi Michael,
Did you find a solution in the meantime?
I'm having the same issue.
Martin
Hi Martin
Michael
Ok, thanks.
question: did it happen with any form or only with forms having custom FieldTypes?
(I'm having trouble with customs)
Martin
