  • PeterM 7 posts 37 karma points
    Jul 03, 2012 @ 14:07
    PeterM
    Export Contour entries into CSV from frontend
    I have a site where the customer does not log into Umbraco backend only frontend. But they would still like to be able to download all the Contour entries in an Excel file (or CSV)
    What possible ways are there to solve this?
    • Iterate through all records manually making the CSV file
    • use the same export functions as backend? is there an API to this?
    • Use some sort of XML2EXCEL or XML2CSV converter?
    • Other ways?
    There is around 2000 entries with 30 questions.
    Thanks for helping
  • Henri Toivonen 77 posts 111 karma points
    Jul 06, 2012 @ 11:19
    Henri Toivonen
    I have the same problem. Any ideas?
