  • Lachlann 344 posts 626 karma points
    Jul 06, 2012 @ 10:21
    Lachlann
    Backend failing to retrieve entries
    Hey Guys,
    Still running into some issues with my contour install, When I try and retrieve a months worth of samples (around 20 entries) from the database
    /umbraco/plugins/umbracoContour/webservices/records.aspx
    call returns around 21 items but they do not display in the entries list. The green processing message just stays on the screen. I dont seem to get any asp errors or JS errors. My form is a multipage form and has a lare number of fields (around 50 over the 3 steps)
    We are hoping to launch this really soon if possible a quick response would be great, could this be to do with the json size?
    L
  • Muhammad Tahir 12 posts 33 karma points
    Jul 09, 2012 @ 01:40
    Muhammad Tahir
    I am experiencing exactly the same problem. It will be great if anyone from the HQ can look at this issue.
    Jul 09, 2012 @ 02:42
    Muhammad Tahir
    Hi Lachlann,
    I just found a solution. You need to modify the web.config file as follows
     <system.web>
    <httpRuntime requestValidationMode="2.0" executionTimeout="600" maxRequestLength="Number" maxQueryStringLength = "Number"/>
     </system.web>
    <system.webServer>
    <security>
       <requestFiltering>
        <requestLimits
            maxQueryString="Number"
       </requestFiltering>
      </security>
    Number = The max size you want.
    I hope it helps
    M.
    Jul 09, 2012 @ 09:22
    Lachlann
    Hi Muhammad,
    Thanks for your reply, it doesnt seem to have worked for me unfortunatly. The records.aspx call doesnt throw any kind of error and in fact returns the JSON i would expect, it is just that it does not seem to output it to the screen.
    Best
    L
