  • dominik 711 posts 733 karma points
    Aug 07, 2012 @ 14:22
    dominik
    Style Checkbox and Radiobutton lists
    how can i style checkboxlists and radiobutton lists? The text should float right of the radio button or checkbox.
    I tried also to use html tags in the contour backend and it works until i click "update". After clicking "update" it shows undefined
    Aug 07, 2012 @ 14:58
    dominik
    can i change the generated html code? Than i would be able to place a div between the checkbox and the label
    That would also work
  • Comment author was deleted
    Aug 07, 2012 @ 15:05
    Hey Dominik currently you can't change to generated html code of the form but yoou should be able to style it with css
    More control over markup is however the top requested feature (http://issues.umbraco.org/issue/CON-58) and we are looking into ways of making this possible to include this in the next major release
    Tim
    Aug 07, 2012 @ 15:09
    dominik
    i tried to achieve this with css but its not working because i think the input field is not closed correct (closing tag is missing)
    <span id="bla" class="checkboxlist"><input style="border: 1px solid rgb(204, 204, 204);" id="bla" name="" value="" type="checkbox"><label for="">test</label><br>
    Can you please also tell me how i can enable html tags in the contour backend?
    Aug 07, 2012 @ 15:26
    You should be able to target it with the following rule: #contour .radiobuttonlist input for checkbox list ir #contour .checkboxlist input for a checkboxlist
    Html isn't possible for the options since you can only set the contents of the label to some text
    Aug 07, 2012 @ 15:29
    dominik
    We really need a possibility to specify how the html which is generated should look like. I want to add some div classes in the same way as it works in RenderForm.ascs
    Where can i change to input field so it is closed correctly? I think this is an error and will produce invalid html
    Aug 07, 2012 @ 15:31
    dominik
    I tried the following:
    #contour span.checkboxlist input {float:left; width:30px;}
    #contour span.checkboxlist label {float:left; width:200px;}
    So the label text is shown right the inputfield (if text is longer than one line)
    This does not work because the input field is not closed correctyl I think
    Aug 07, 2012 @ 15:41
    Just tried to target those and it works fine, do you see any affect when you float the input to right?
    Aug 07, 2012 @ 15:43
    dominik
    no float right does also not work because input field is not closed. Just let me know how i can close the input tag so it must look like this I think:
    <input type="checkbox" name="" />
    <label>text</label>
    As it is rendered now:
    <input type="checkbox" name="">
    <label>text</label>
    So it always think that label is inside <input>
    Aug 07, 2012 @ 15:57
    Looks like a bug the, added it to our issue tracker and will take a closer look at this http://issues.umbraco.org/issue/CON-73 would you mind telling me what browser you are using since I can't reproduce the styling issue
    Aug 07, 2012 @ 16:01
    dominik
    firefox 14.0.1
    google chrome 21.0.1180.60 m
    It would be fine to configure the html which is rendered later - otherwise i am not able to add divs, spans etc for styling the form
    Aug 07, 2012 @ 16:05
    Is the default contour stylesheet still added in your case (you can check on the form settings)? Might be that some rules in there are causing the issue
    Aug 07, 2012 @ 16:08
    dominik
    yes this is added
    Aug 07, 2012 @ 16:41
    Ok could you see if the styling has better effect when you disable the default one
