Topic author was deleted
Aug 14, 2012 @ 11:20
Contour 1.1.13 changes
Here is an overview of the changes in Contour 1.1.13 which is out today :)
1.1.13 - August 2012 Fixed: CON-81 threading issue with workflow types Fixed: CON-49 Recordset action with settings results in YSOD Fixed: CON-51 Checkbox field setting type not holding state when used on a field type Fixed: CON-52 No need for deleted state in entries viewer Fixed: CON-29 Extender controls may not be registered after PreRender. Fixed: CON-56 Adding custom fieldtype with addition settings and removing a settings breaks the form Fixed: CON-70 default members values in forms Fixed: CON-71 /umbraco_client/jqueryui.js file not found on form designer Fixed: CON-63 Entries viewer, forms that have lots if fields, UI runs off the page Fixed: CON-69 Create form from form picker bug Fixed: CON-68 Lots of fields kills entries viewer Fixed: CON-79 Sometimes slashes in the record will break entries viewer Fixed: CON-72 Install SQL script failing on Azure Fixed: CON-82 Improve setting validation on default datasources Fixed: CON-83 Settings not being validated on workflow editor Fixed: CON-84 Improve setting validation on default workflows Fixed: CON-86 Contour license conflicting with 3rd party licenses Fixed: CON-67 Entries viewer, sort columns by the way they exist on the form Fixed: CON-59 Record viewer issue when updating form Fixed: CON-88 Error on SQL Azure, Tables without a clustered index are not supported in this version of SQL Server Fixed: CON-90 Email record record actions needs different icon Added: CON-80 no need for license file when it's a local browser request (full mode) Added: CON-50 Add version number to config and dashboard Added: CON-74 Add version number to DLLs Added: CON-75 When adding a new field, auto scroll down to the add field form
Thanks Tim! This release is a great improvement. Thanks for all of your awesome work!
@sun, the Recaptcha field type is available as part of the Contour Contrib package. If you don't want the rest of the field types, workflows, etc found in the package, the project is open source (MIT licensed), you can pull the Recaptcha code out and write your own dll. See the developer documentation for more details on how to create custom fieldtypes.
I've added some comments to a few of the issues, describing the bugs in more detail. However, these issues are now marked as fixed. Would it be best to create new issues? If so, what would be the best way to go about doing that? I don't have any rights.
Hi Tim, Congratulations with the release. Have you tried it with Umbraco 4.7.2? I cant make it work frontend … The form is not showing up, no errors at all :(
@DOuglas thanks again for the feedback :) I'll reopen the issues it should be possible to create issues soon just waiting on an import of the core issues and then it will be possible
It only affects clean installs on sql server or sql azure of 1.1.13 and 1.1.13.1, upgrades aren't affected
If you experience the bug please execute the following script
ALTER TABLE [UFRecordDataBit]
DROP CONSTRAINT PK_UFRecordDataBit
ALTER TABLE [UFRecordDataDateTime]
DROP CONSTRAINT PK_UFRecordDataDateTime
ALTER TABLE [UFRecordDataInteger]
DROP CONSTRAINT PK_UFRecordDataInteger
ALTER TABLE [UFRecordDataLongString]
DROP CONSTRAINT PK_UFRecordDataLongString
ALTER TABLE [UFRecordDataString]
DROP CONSTRAINT PK_UFRecordDataString
Tim, what's the best way to report bugs and feature requests for Contour? The issue tracker doesn't appear to allow the general public (like me) to add new items to the Contour project. Should I just report them here on the forum?
A couple things, I'd like to add are that uploaded files have a link associated to them in the entries viewer and that the submit button text be customizable on a per form basis (perhaps a form setting?).
Thanks for the quick reply. The thing is that my boss is kind of stubborn and insists in upgrading from 1.1.9 to 1.1.13 before trying out 3.0.9. That's why I asked about 1.1.13's compatibility with 4.11.5.
Package and upgrade files can be found on the project page http://our.umbraco.org/projects/umbraco-pro/contour
Issue tracker is also public now and can be found at http://issues.umbraco.org/issues/CON
Thanks for you hard work.
One question:
Can add Recaptcha to Contour core code? and make it can customize which characaters can be used? It's more and more important now.
If this can't be done, Please tell me how to do it.
@Tim Geyssens,
http://issues.umbraco.org/issue/CON-68#comment=67-2335
http://issues.umbraco.org/issue/CON-63#comment=67-2334
Hi Tim,
Comment author was deleted
@Anders just tried on an Umbraco 4.7.2 and it works ... , does the preview form work and the contour section?
Hey Tim,
Thanks for your reply. Do you have 2 minutes on Skype where I can show you the problem?
@Anders, sure could you mail me your skype username , tg at umbraco dot com
1.1.13.1 is out fixing 2 bugs that sneaked into the 1.1.13 release
Fixed: CON-91 Value cannot be null. Parameter name: g
Apparently a show stopper sneaked into the 1.1.13 release http://issues.umbraco.org/issue/CON-98 so 1.1.13.2 is just out fixing this issue
@Tim
The reason it did not work is that the Contour is a. NET usercontrol and these can not print through XSLT - so my mistake :)
@Anders ah makes sense now, thanks for letting me know ;)
Hi. Did someone try this version with Umbraco 4.11.5? Thank you.
@Nicolas lastest version 3.0.9 should work on both v4 and v6 so also 4.11.5
@Tim
Not 100% sure but I think it should work
OK. I'll give it a shot and if anything comes up I'll let you know. Thanks!
Details on how to upgrade can be found here: http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
