Whats the best way to ugrade form 1.1.11
I tried installing the upgrade, but get the following error:
System.Exception: Error unpacking extension... ---> System.IO.FileNotFoundException: Could not find file
Should i just install 1.1.13 or uninstall 1.1.11 first?!?
Whats the best way?
Comment author was deleted
Hey Claus,
The upgrade archive isn't a package but just the Contour files so you can just xcopy those over the existing ones to upgrade :)
best way to upgrade from 1.1.11?
Whats the best way?
Hey Claus,
