Custom FieldType: settings is null during RenderPreview
Hello -
I've added a setting here:
[Umbraco.Forms.Core.Attributes.Setting("Lists to Display", description = "The selected lists to which the user can subscribe", control = "Liquid.Contour.Extensions.CampaignMonitorListsFieldSettingsType", assembly = "Liquid.Contour.Extensions")]
public string ListsToInclude
{get;set;}
I can see the setting control - and choose my lists fine. If i edit the field, the value is preserved fine. All good.
Problem is...the value is null when RenderPreview - so i can't use the setting at all to render the form value.
I use the same pattern in workflowtype, recordactiontype, etc - and have no issues accessing this setting during "execute" - but in renderpreview of the fieldtype it is always null.
Any help would be appreciated! I'm sure i've missed something obvious as i'm new to this stuff, but i'm pulling my hair out here!
RenderPreview only affects the form builder, so it's the preview you get in the designer when adding and editing fields... so it might be that the settings aren't available in that method but since it's only used for the designer... you can simply return some sample markup
No - it doesn't work on the actual form either. However i do have to correct my original post as i left the form and came back to it (in designer) and found the issue is that the value is NOT getting saved at all. I mistakenly said that the value was preserved. (i had not moved off the page).
I can set the value, but if i save the form and then return to it and edit the same field, the value is no longer set.
As i mentioned the very same custom control DOES retain its value when used for workflytypes and record action types.
Further debugging shows that when i open the form to edit the field, i see the custom fieldsettingstype get instantiated.
However, after i click on the "update" button in the designer, it does NOT hit my breakpoint in the set of the custom fieldsettingstype class. (never sets the value).
I goes right to the Renderpreview of the fieldtype.
Any thoughts as to why when i submit the form, i'm not seeing it set the value in my custom fieldsettingstype?
Again - when i run the same tests using the fieldsettingstype in workflow, i DO see the value get set (my breakpoint is hit).
Update: I swapped out with some standard fieldsettingstypes and all is well. My custom fieldsettings type works with all other provider types, so I'm chalking this up to a bug with custom fieldsettingtypes on custom fieldtypes.
My workaround currently is using a custom prevalue source type (which utilizes my custom fieldsettings type to filter the sources).
Then, on the form, i set the field to a STANDARD checkbox list and set it's prevalues to the custom prevalue list i just created.
A bit more awkward than i was hoping (forces the user to visit the prevalues section seperately) but it will do until the custom fieldtypes/custom fieldsettingstype issue is resolved.
Hello -
[Umbraco.Forms.Core.Attributes.Setting("Lists to Display", description = "The selected lists to which the user can subscribe", control = "Liquid.Contour.Extensions.CampaignMonitorListsFieldSettingsType", assembly = "Liquid.Contour.Extensions")] public string ListsToInclude {get;set;}I can see the setting control - and choose my lists fine. If i edit the field, the value is preserved fine. All good.
Comment author was deleted
Does it work ok when you test the actual form
Regards,
Tim
Thanks for the response Tim.
