After working with contour the past couple days, I have a few issues with that seem like basic things, but either i don't understand something or they aren't working. I'm using umbraco 4.8.1 and contour 1.1.13.
1. Setting /changing values of form fields on the "Submitted" stage of a custom workflow doesn't work. Same code Does work in the "Approved" state. For some instances this doesn't matter, but in a manual approval flow, this is a serious issue.
2. Entries viewer - all collumns have a cursor pointer - but only the "created date" actually toggles the sort order of that column. I'd expect all columns to toggle their sort. The ability to sort and filter entries is a very important feature that i'm hoping simply isn't working in my case - if not, please add - i'm sure it will be one of the first complaints by my new umbraco clients.
3. haven't tried this yet - but it's on the lits - easiest way to promote forms, workflows, etc from dev to staging to prod - is this needed to be a manual process? or has contour finally been integrated into courier? Being they are both commercial offerings - i'd hope that at somepoint the two products would play nicely together :)
If these are bugs, do i report them via the form on the support page? or is contour now in a full blown issue tracker?
If these are feature requests, please add them to the list asap!
Bugs or missing features?
Comment author was deleted
Hey Steve,
Thanks for your feedback
Contour has a public issue tracker since a couple of weeks, you can find it here: http://issues.umbraco.org/issues/CON
If you submit bugs trough the umbraco.com site they will also appear on the issue tracker
1 and 2 have been added recently http://issues.umbraco.org/issue/CON-92 and http://issues.umbraco.org/issue/CON-93 and they will be looked at for the coming 3.0 release
For 3 there is a Contour provider for Courier that allows you to transfer forms with Courier you can find it here http://couriercontrib.codeplex.com
