  • Jessica Nordbeck 32 posts 102 karma points
    Aug 31, 2012 @ 12:54
    Jessica Nordbeck
    Extending Contour DatePicker
    Hi all
    We have a form based on Contour with a DatePicker field. We've got the request to add validation to the selected date and the request says:
    - If today's date is closer than 5 days to the selected date, the form should not be possible to submit.
    Any ideas on how to solve this?
    Aug 31, 2012 @ 13:22
    Ismail Mayat
    Jessica,
    You could make the field a textfield then use jquery date picker and then set options of the jquery date picker so that 5 days close todays date not pickable.
    See http://jqueryui.com/demos/datepicker/
    Also see http://www.world-of-incentives.com/request-for-proposal.aspx on this site the date pickers are jquery ui date pickers although not range restricted but you can see what I have done.
    Regards
    Ismail
    Aug 31, 2012 @ 15:25
    Jessica Nordbeck
    Thanks a lot! That looks very neat :-) I will try that out!
  • Ryan Green 63 posts 83 karma points
    Jan 22, 2014 @ 19:18
    Ryan Green
    I have the code working in jsfiddle, but where should I place the script to get it to attach to the .datepickerfield on my form.
    I tried looking in the source code, to use both the ID or the class of the field, but it doesn't work. The script is not even changing the field.
