  • iWuha 1 post 50 karma points
    Oct 05, 2012 @ 08:15
    iWuha
    custom field type not saving
    Hi, I created a custom captch fieldtype using MSCaptcha. The custom control seems to be working fine in a normal .aspx page, but it's not working when it's within contour form page. I added a custom validator to validate the captcha text, the validation works fine but the form is not submitting even though the page is valid. I wonder if there's anything wrong my fieldtype? Any help would be appreciated. Thanks.
    Here is the code for my custom captcha control:
    using System;
    using System.Linq;
    using System.Web.UI;
    using System.Web.UI.WebControls;
    using MSCaptcha;
    namespace Model.Forms.Controls
        public class Captcha : TextBox
            public CaptchaControl CaptchaControl
                get
                    EnsureChildControls();
                    return this.captcha;
                set
                    this.captcha = value;
            private CaptchaControl captcha;
            private CustomValidator captchaVal;
            protected override void OnInit(EventArgs e)
                string vGroup = string.Empty;
                List<RequiredFieldValidator> reqValidators = this.ControlsByTypeUsingAncestor<RequiredFieldValidator>(this.Page);
                if (reqValidators != null)
                    var validatorWithGroupSet = (from v in reqValidators
                                                 where v.ValidationGroup != string.Empty
                                                 select v);
                    if (validatorWithGroupSet != null)
                        vGroup = validatorWithGroupSet.FirstOrDefault().ValidationGroup;
                this.captcha = new CaptchaControl();
                this.captcha.CaptchaBackgroundNoise = CaptchaImage.backgroundNoiseLevel.Low;
                this.captcha.NoiseColor = System.Drawing.Color.FromArgb(251, 194, 196);
                this.captcha.CaptchaLength = 4;
                this.captcha.CaptchaHeight = 60;
                this.captcha.CaptchaWidth = 250;
                this.captcha.CaptchaLineNoise = CaptchaImage.lineNoiseLevel.None;
                this.captcha.CaptchaMinTimeout = 5;
                this.captcha.CaptchaMaxTimeout = 240;
                base.CssClass = "text";
                this.captchaVal = new CustomValidator();
                this.captchaVal.ErrorMessage = "Invalid code";
                this.captchaVal.ServerValidate += new ServerValidateEventHandler(captchaVal_ServerValidate);
                this.captchaVal.IsValid = true;
                this.captchaVal.Display = ValidatorDisplay.Dynamic;
                this.captchaVal.ValidateEmptyText = true;
                this.captchaVal.EnableClientScript = false;
                this.captchaVal.CssClass = "contourError";
                if (!string.IsNullOrEmpty(vGroup))
                    base.ValidationGroup = vGroup;
                    this.captchaVal.ValidationGroup = vGroup;
                base.Controls.Add(this.captchaVal);
                base.Controls.Add(this.captcha);
            void captchaVal_ServerValidate(object source, ServerValidateEventArgs args)
                try
                    args.IsValid = ValidateCaptcha();
                catch
                    args.IsValid = false;
            private bool ValidateCaptcha()
                bool flag = true;
                if (this.captcha != null)
                    if (string.IsNullOrEmpty(base.Text))
                        flag = false;
                    else
                        this.captcha.ValidateCaptcha(base.Text);
                        flag = this.captcha.UserValidated;
                else
                    flag = false;
                if (flag)
                    this.captchaVal.Style.Add("display", "none");
                else
                    this.captchaVal.Style.Add("display", "block");
                return flag;
            protected override void Render(HtmlTextWriter writer)
                base.RenderChildren(writer);
                base.Render(writer);
            /// <summary>
            /// get find control method using generics
            /// </summary>
            /// <typeparam name="T">type of item you want</typeparam>
            /// <param name="ancestor">parent to start looking from</param>
            /// <returns>collection of T items</returns>
            public List<T> ControlsByTypeUsingAncestor<T>(Control ancestor) where T : Control
                var controls = new List<T>();
                //Append to search results if we match the type
                if (typeof(T).IsAssignableFrom(ancestor.GetType()))
                    controls.Add((T)ancestor);
                //Recurse into child controls
                foreach (Control ctrl in ancestor.Controls)
                    controls.AddRange(ControlsByTypeUsingAncestor<T>(ctrl));
                return controls;
    And my custom field type:
    using System;
    using Umbraco.Forms.Core;
    namespace Model.Forms.FieldTypes
        public class Captcha : FieldType
            public Controls.Captcha CaptchaControl;
            public List<object> Value;
            public Captcha()
                base.Id = new Guid("F8C089B9-7D8F-47B0-A594-9FD9903FBF42");
                base.Name = "Captcha";
                base.Description = "Renders a Captcha";
                this.Icon = "textfield.png";
                this.DataType = FieldDataType.String;
                this.Value = new List<object>();
                this.CaptchaControl = new Controls.Captcha();
            public override WebControl Editor
                get
                    return this.CaptchaControl;
                set
                    base.Editor = value;
            public override List<object> Values
                get
                    if (!string.IsNullOrEmpty(this.CaptchaControl.Text))
                        this.Value.Clear();
                        this.Value.Add(this.CaptchaControl.Text);
                    return this.Value;
                set
                    this.Value = value;
            public override bool SupportsPrevalues
                get
                    return false;
            public override bool SupportsRegex
                get
                    return false;
            public override string RenderPreview()
                return "<img src=\"/Images/layout/capex.jpg\" alt=\"captcha\" /><br /><input type=\"text\" class=\"textfield\" />";
            public override string RenderPreviewWithPrevalues(List<object> prevalues)
                return this.RenderPreview();
  • Andrew Weddle 1 post 21 karma points
    Aug 15, 2014 @ 13:37
    Andrew Weddle
    Hi iWuha,
    Sorry to drag up an old thread, but I have a requirement for the same functionality as the above.  I have found the source of your problem, but not a solution.
    The problem is that the captchaVal_ServerValidate event seems to be firing twice.  The first time it validates successfully, however the second time it runs, the ValidateCaptcha() throws an exception and hence the catch returns false.
    I have implemented a workaround, but it's so hacky and I'm not proud that I'm not even going to post the code here!
    Did you ever get this working correctly?
    Andrew
