  • Ally Watson 16 posts 37 karma points
    Nov 01, 2012 @ 16:12
    Ally Watson
    How can I customise contour to set cookie on back? Problem with persisting data when navigating back and forth
    User scenario:- I have created a large 2 step form with contour. I am on step two of my form and I have completed all the fields and I'm ready to submit. Before submitting I would like to press previous to make sure I am happy with all my fields before I submit. When I press next all the data on my step 2 has gone.
    I understand that contour creates a cookie called contour_" + pageId + "_" + formId when you press next. Is there a way so it can also do this when pressing previous?
    Thanks in advance,
    Ally
  • Kenny Burns 173 posts 305 karma points
    Nov 06, 2012 @ 14:05
    Kenny Burns
    Hi Ally,
    Is the data getting saved when you are pressing previous? If it is, might it be a case of loading in the cookie again?
    http://our.umbraco.org/forum/umbraco-pro/contour/15322-Contour-Caching-Form-Values-on-a-Multi-Step-Form-How-to-Clear?p=2
    Looks like the cookie is just a reference to the form that is being filled in.
    (total stab in the dark!!)
    Kenny
    Nov 08, 2012 @ 12:13
    Kenny Burns
    Hi Ally,
    Seen another post that says if you have quite a large form and it is not saving you might need to increase the maxJsonLength in the web.config.
    http://www.citytechinc.com/us/en/blog/2011/12/umbraco_6_tips_for.html
    Worth a shot maybe?
    Kenny
    Nov 08, 2012 @ 12:28
    Ally Watson
    Hi Kenny,
    Thanks for the responses. Having had a look at the db the xml for the second step of the form doesn't seem to be being saved when pressing previous. Only when going forward does it change the record status to 'partially submitted' and updates the xml within the db. Not sure if it's a case of overriding an event somewhere. Still looking in to it. Will keep you updated if we make progress on this.
    Thanks again,
    Ally
