I saw the Contour 3 blog regarding conditional logic. An outstanding feature!!
Building on this, is it possible to conditionally alter the workflow step, "Save as Umbraco Document", namley the location where the document saves, based on information entered into the Contour form by the user. Currently, we are doing this manually. So in the image below, each menu item is linked to a separate Contour form, all identical except the workflow step, Publish as Umbraco document, where a unique node in the tree is specified (corresponding to the lab involved). The result is a publication is added to that Lab's site. The publication ID is the name of the node and also the programming logic that populates the publication. See http://contelab.surgery.ucsf.edu/publications.aspx
The goal would be to have a single menu item on the front end that presents a series of radio buttons in the Contour form. Depending on which radio button was clicked, the workflow "Save as Umbraco document" would be modified to correspond to the publication area (node) in the tree for that website.
Is there a way to do this using a workflow routine? In other words, is it programmatically possible given the host of new features in Contour 3?
Question re: Conditional Logic in Contour 3
Tim,
If so, do you have any recommendations?
