  • Tucker 5 posts 25 karma points
    Nov 23, 2012 @ 08:04
    Tucker
    Problems installing Contour 3 into Umbraco 4.10.1
    I tried to install Contour 3 on a fresh install of Umbraco 4.10.1 but received the following error message:
    Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
    I’m running it locally using .NET 4 and SQL Server 2008 R2. What am I doing wrong?
  • SC Digital Services Team 104 posts 171 karma points
    Nov 23, 2012 @ 10:24
    This also occurs on v4.9.0 - although this is an existing test installation and an upgrade of Contour using the files in the upgrade zip & SQL script
  • Comment author was deleted
    Nov 23, 2012 @ 10:29
    Hi guys, could you tell me if you have .net framework 4.5 installed? Might be related to that, looking into the issue now
    Nov 23, 2012 @ 10:59
    Hi Tim,
    We are just using the 4.0 framework.
    Nov 23, 2012 @ 11:01
    So the 4.5 framework isn't installed on the machine you are running the site on? From what I can find it has something todo with that, I'll let you know once I find a solution
    Nov 23, 2012 @ 11:03
    Installing the 4.5 framework should resolve the issue but I'm looking into a solution that doesn't need that...
    Nov 23, 2012 @ 11:13
    Thanks Tim,
    I'm just setting up a test system based on working backups of our existing test installation. I'll upgrade again with the standard 4.0 framework, then try installing version 4.5 if I get any problems. I'll let you know how I get on!
    Nov 23, 2012 @ 11:23
    Tucker
    Hi Tim, I'm also using the 4.0 framework.
    Nov 23, 2012 @ 11:25
    @Tucker, thanks , currently installing .net framework 4.5 should resolve the issue but I'm also looking into a fix
    Nov 23, 2012 @ 12:05
    Thanks Tim,
    I'm just setting up a test systems based on working backups of our existing test installation. I'll upgrade again with the standard 4.0 framework, then try installing version 4.5 if I get any problems. I'll let you know how I get on!
    Nov 23, 2012 @ 12:33
    Tucker
    Hi Tim, I've just installed .net framework 4.5 and Contour 3 looks to have installed correctly, I'll shout if I have any problems! Thanks for your help.
    Nov 23, 2012 @ 12:40
    @Tucker, thanks for confirming!
    Nov 23, 2012 @ 12:57
    Seems it's an issue with our build server, so currently installing 4.5 framework will solve it but we'll look into the error next week
    Nov 26, 2012 @ 13:58
    Hi Tim,
    I know we are a bit late to reply, but thought you'd like to know that we've installed the 4.5 framework on our test systems and all the Contour and razor issues are now resolved.
    Nov 26, 2012 @ 14:16
    great thanks for confirming
  • B.SheshuKumar 10 posts 30 karma points
    Nov 26, 2012 @ 14:41
    B.SheshuKumar
    Can u please explain briefly that how can we overcome these problem..
    when i try to install the contour 3.0 in my umbraco 4.10 i face the above problem.When i try to install the Contour manually by changing all the web.config also not bring the solution to me...
    So please do this need ful
    B.Sheshu kumar
    b.sheshukumar@gmail.com
    Nov 26, 2012 @ 14:42
    @Kumar you need to install the .net framework 4.5 if you see that error
    Nov 26, 2012 @ 14:44
    B.SheshuKumar
    Hi Tim,
    That means it doesnt work in the .net framework 4.0  ?
    Nov 26, 2012 @ 14:45
    @Kumar it should but currently it doesn't due to an issue on our build server, we are looking into it but currently the only way to fix is to install .net framework 4.5
    Nov 26, 2012 @ 14:48
    B.SheshuKumar
    Hi Tim
    Actually iam new to umbraco.so,which will guide the Perfect flow to me...to proceed..
    And when i install the umbraco i'am able to work with only single website..and when i try to open the new site..it doesnot showing the admin session in the toolbar.
    Please explain me this too...
    Thanks & Regards
    B.SheshuKumar
    Nov 26, 2012 @ 14:49
    B.SheshuKumar
    Thank you tim..
    May i know which Contour version's are compatable with the .net 4.0...?
    Nov 26, 2012 @ 14:50
    @Kumar versions before 3.0
    Nov 26, 2012 @ 15:22
    B.SheshuKumar
     thanq TIM
    I will do that...
  • Fergus Davidson 309 posts 588 karma points
    Nov 26, 2012 @ 16:58
    Fergus Davidson
    i just upgraded an existing contour to v3 and i have the same problem - issues in the back-end and all xslt failing on the front-end.
    presumably related to this thread: http://our.umbraco.org/forum/getting-started/installing-umbraco/34986-Umbraco-49-Could-not-load-type-'SystemRuntimeCompilerServicesExtensionAttribute'-
     UPDATE:
    upgrading the server to .net 4.5 seems to have fixed the issue.
    Tim - is it possible to have a .net 4 version of contour?
    Nov 27, 2012 @ 05:48
    B.SheshuKumar
    Hi Tim
    Can u  explain me how to create a new website after the sample website is created(After installation of umbraco 4.10)
     I get one sample website with starterkit and skin while installing the umbraco 4.10 and when i try to open the new website from template.It is not showing the admin session in the toolbar(which will navigate to the browser).
    Please tell me how to create the new website similar to sample webiste which i got while installing the umbraco 4.9
    Thanks & Regards..
    B.Sheshu kumar
    Nov 27, 2012 @ 06:09
    B.SheshuKumar
    If i want any new website I am reinstalling the umbraco with the compatable database(mssql). Is this is the right way to get the new website in umbraco.?
    Thanks & Regards
    B.Sheshu Kumar
    Nov 27, 2012 @ 13:41
    3.0.1 WIP build should work without .net 4.5 http://nightly.umbraco.org/Umbraco%20Contour/3.0.1%20WIP/
    Nov 27, 2012 @ 14:14
    B.SheshuKumar
    Thank you very much tim..
    Actually i solve this problem by installing the .net frame work 4.5
    But..i want to know that how can I create a new website.?
    Please do this need ful
    Nov 27, 2012 @ 15:25
    New version out that doesn't need 4.5 framework v3.0.1 (also easier upgrade) http://our.umbraco.org/projects/umbraco-pro/contour
