I've recently started to work with Umbraco Contour. And I got this issue, the second time I'm trying to post a form, it will just become blank.
However, the first time I'm posting the form it will complete and I will be sent to another page that I selected in Contour. But if I return right after to the same form and try to post it again ( with new values etc. ) It will just refresh the page and the form will become invisible. ( No record in the database nor sent to another page )
I've tried to solve this issue and the only thing I have came up with is that if I clean all my cache and it will work, i.e. If i clean the cache between my posts.
I've also tried to change the settings in UmbracoContour.config with no success: <setting key="DisableFormCaching" value="true" />
Cache problem?
Best Regards,
Hampus
Comment author was deleted
This was a bug, fixed in the latest release so you can just upgrade http://our.umbraco.org/projects/umbraco-pro/contour
Btw had nothing todo with the form caching (was tempdata that didn't clear)
Thanks for your reply and for the fix, glad you understood the issue.
Best Regards,
Hampus
