I wasn't able to find anything real conclusive on this, so I figured I would start a new thread.
I'm using Contour 3.0.2 - Does anyone have any thoughts as to if/how you can create a navigation for forms with multiple steps? We want to create a tab navigation for our forms so you can skip over sections that contain non-required fields. For example if we click on the 4th tab, we want to jump to the 4th step.
When using the razor macro you can have complete control over the form markup so adding a navigation should be easy, but making it skip steps will be trickier.
What I would suggest is to update the view that is outputting the form and simply output all pages at once (but hide them with some js) then skipping steps would just be hiding /showing the page you want
Contour Multi-step Form Pagination?
Can this be done?
Comment author was deleted
Hi Corey,
