Hi Everyone,Is there a recommended way to remove Contour entries from a database? I have a site with a MySQL database that is 1.2GB in size, 1.1GB of that consists of unused Contour entries!
Kind Regards,mmmoustache
Comment author was deleted
There is no UI component to do this but if you want to bulk remove records a direct sql statement should do the trick
Removing Contour entries from MySQL db
Hi Everyone,
Kind Regards,
mmmoustache
