  • Sander van de Pas 74 posts 147 karma points
    Dec 13, 2012 @ 11:09
    Sander van de Pas
    Changing default mail templates per form
    II'm using Contour 3.0.1 for sending mails whithin a site. Now I'm already very happy with the possibility to customize each form with Razor.
    But for 1 form I have to customize the e-mail template wich will be send when you click on the submit button. It has an hidden value (id) which I need to get a specific object and add that object to the mail.
    Is there a way to customize these mail templates per form?
    Thanks in advance!
    Grtz Sander
  • Comment author was deleted
    Dec 13, 2012 @ 11:22
    Hi Sander,
    A custom workflow would be what you need here, to get started you can take a look at the current workflow sourcecode and adjust it to your needs http://our.umbraco.org/projects/developer-tools/umbraco-contour-shared-source, contour contrib also has some great examples http://contourcontrib.codeplex.com/
