  • Martin Griffiths 826 posts 1269 karma points c-trib
    Dec 19, 2012 @ 11:35
    Martin Griffiths
    CodeFirst Prevalue Datasource id issue
    Tim hopefully you'll pick on this one.
    If I create a pre-value datasource with say 5 entries for use with a radiobuttonlist and set the id's from 1-5 and use the datasource more than once in the same form, the id's clash on the form. This causes label problems ie. selecting the label further down the form changes the state of the first group (of a radiobutton list)
    Is there any way around this?
    Martin
  • Comment author was deleted
    Dec 19, 2012 @ 13:27
    Added to our issue tracker will take a look this week and report back http://issues.umbraco.org/issue/CON-191
    Dec 19, 2012 @ 13:54
    Ok looks like an update of some of the views should do it, working on it now :) thanks for reporting the issue :)
    Dec 19, 2012 @ 14:54
    WIll be fixed in 3.0.5, to do a quickfix on your install, you'll need to update 2 views
    \Umbraco\plugins\umbracoContour\Views\FieldType.RadioButtonList.cshtml
    \Umbraco\plugins\umbracoContour\Views\FieldType.CheckBoxList.cshtml
    where it says @pv.id replace it with @string.Concat(Model.Id,"_",pv.Id)
    Dec 19, 2012 @ 15:48
    Martin Griffiths
    No worries Tim, you always seem so prompt at jumping on it. So i'm forever greatful.
    Martin
    Dec 19, 2012 @ 16:17
    Martin Griffiths
    Hi Tim
    One thing worth noting, Razor seems to be a bit flaky when handling whitespace/newline(s).
    I've had to remove the blank line (2) from both FieldType.RadioButtonList.cshtml and FieldType.CheckBoxList.cshtml. I also removed some of the formatting from form.cshtml to ensure that the label caption didnt have masses of whitespace either side of it.
    Use the Chrome Element picker to see what I mean. It has caused me some CSS formatting issues.
    Martin
    Dec 19, 2012 @ 17:41
    Martin Griffiths
    Hi Tim
    I'm trying to move my codefirst dll from dev to staging but keep getting the following error any idea why it might be doing this???
    Sequence contains no matching element
