When I try to render my form with the new razor macro I get the following message:
The partial view '/umbraco/plugins/umbracoContour/Views/Fieldtype.comparetextbox.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: /umbraco/plugins/umbracoContour/Views/Fieldtype.comparetextbox.cshtml
Hi looks like you are using the member tools and outputting with a razor macro. The member tools fieldtypes don't have support for the razor macro and the fieldtypes on that one where also kind of a hack, it's better to look at http://www.nibble.be/?p=205 that post has to code for registration, login, profile, change password
Partial view is missing
The partial view '/umbraco/plugins/umbracoContour/Views/Fieldtype.comparetextbox.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: /umbraco/plugins/umbracoContour/Views/Fieldtype.comparetextbox.cshtmlComment author was deleted
