  • Mike 80 posts 101 karma points
    Dec 24, 2012 @ 12:06
    Mike
    Umbraco 4.5.2 and .NET 3.5
    Is Contour compatible with "Umbraco 4.5.2 and .NET 3.5", or will we need .NET 4.0 for it to work. Could not find any trial version, is there one so I can test if it will work before buying/recommending to a client?
    thanks
  • Grant Thomas 291 posts 324 karma points
    Dec 24, 2012 @ 12:10
    Grant Thomas
    I would say, given that it's a primary product, there'll be compatibility, but not backwards compatibility support with recent versions of Contour. The software comes as a trial as standard (from what I remember) and so you can install, develop and use it locally, then purchase a license to lift restrictions when happy.
    What I would suggest, though, is that you use a newer version of Umbraco if possible - 4.5.2 is quite out of date now.
    Dec 24, 2012 @ 15:37
    Mike
    Yes, but the server does not yet support .NET 4, that's why were stuck with 4.5.2 at the moment.
    So if it works on .NET 3.5/4.5.2 would be perfect. and on upgrage would still work..
    thanks
  • Comment author was deleted
    Dec 27, 2012 @ 10:36
    Hi Mike,
    The latest version requires .net 4.0 but if you try version 1.1.9 it should work, you can find the download here http://our.umbraco.org/projects/umbraco-pro/contour
