  • Martin Griffiths 826 posts 1269 karma points c-trib
    Jan 04, 2013 @ 11:39
    Martin Griffiths
    Contour CodeFirst SendToPage
    Hi Tim
    Sorry to keep firing all these questions at you! But I absolutely love the work you've done and i'm determined to have a complete solution up and running in CodeFirst.
    I've just setup the SendToPage attribute which I'm assuming is simply a page id. But upon rebuilding the DLL it's not appearing in the form. Still says select node, if I export the form the SendToPage just has a zero in it.
    Please help!
    Martin
  • Comment author was deleted
    Jan 04, 2013 @ 12:01
    Will check (will be on monday), thanks for reporting
    Jan 07, 2013 @ 10:10
    Can confirm the issue (add to our tracker) http://issues.umbraco.org/issue/CON-201 looking into it now
    Jan 07, 2013 @ 10:16
    Fixed it you'll need to update to 3.0.6 WIP found here http://nightly.umbraco.org/Umbraco%20Contour/3.0.6%20WIP/
    Jan 08, 2013 @ 13:42
    Martin Griffiths
    Hi Tim
    Confirmed as working for me, many thanks
    Martin
    Jan 08, 2013 @ 15:55
    Great thanks for confirming
