    Jan 07, 2013 @ 16:28
    Contour 3.0.5 double sections?
    Hi guys
    We have just installed the above version of Contour on Umbraco 4.11.1 - the weird thing is that all the section, forms, data source and prevalues are all listed double?
    How can we fix this so they're only listed once as they're supposed to?
    Looking forward to hearing from someone with an idea :)
  • Comment author was deleted
    Jan 07, 2013 @ 16:29
    That's strange, could you check the \config\trees.config file if they are also in there twice?
    Jan 07, 2013 @ 16:35
    If so remove the double entries from that file :)
    Jan 07, 2013 @ 16:40
    Hi Tim
    Weird, yes they were in there twice :)
    Thanks a lot.
