Preview not working after upgrade to 3.0.5 for custom fieldtypes
I have some custom fieldtypes in my contour solution. After a upgrade to version 3.0.5 my preview of the forms is not working anymore. I get this error
The partial view '/umbraco/plugins/umbracoContour/Views/Fieldtype.datepickerwithcontextdefaultvalue.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: /umbraco/plugins/umbracoContour/Views/Fieldtype.datepickerwithcontextdefaultvalue.cshtml
I noticed the previewpage has changed to previewFormDialogMvc.aspx
How can I get the old preview back
Comment author was deleted
If you update the page \Umbraco\plugins\umbracoContour\editForm.aspx look for previewFormDialogMvc.aspx and change to previewFormDialog.aspx
I'll make this a config setting in the next release
Tim
That worked, but introduced another issue. My conditions are not working now when I am in preview mode.
And with some further checking forms added by the usercontrol macro in a page don't have the conditions working either
Usercontrol macro doesn't support conditions :( it's one of the advantages of moving to mvc and razor , usercontrol one will be deprecated
What needs to be done to make my custom fieldtypes work with razor ? Is there some documentation somewhere ?
Dave
You need to provide a view for it, look at the existing ones at \Umbraco\plugins\umbracoContour\Views\FieldType.*
I'm look at it ? What is properties do I have on the @Model
public string Id { get; set; }
public string Name { get; set; }
public string Caption { get; set; }
public bool Mandatory { get; set; }
public string RequiredErrorMessage { get; set; }
public bool Validate { get; set; }
public string Regex { get; set; }
public string InvalidErrorMessage { get; set; }
public string FieldTypeName { get; set; }
public bool HideLabel { get; set; }
public bool ShowIndicator { get; set; }
public string ToolTip { get; set; }
public string CssClass { get; set; }
public List<Object> RecordValues { get; set; }
public List<PrevalueViewModel> PreValues { get; set; }
public List<FieldSettingViewModel> AdditionalSettings { get; set; }
public bool HasCondition { get; set; }
public FieldConditionActionType ConditionActionType { get; set; }
public FieldConditionLogicType ConditionLogicType { get; set; }
public List<FieldConditionRule> ConditionRules { get; set; }
public string Value { get; }
How do I access my custom properties of my fieldtype ?
Those are in public List<FieldSettingViewModel> AdditionalSettings { get; set; }
Tim is this stuff documented somewhere ? So don't need to post a question everytime I need something ?
Not yet docs will be available in 1/2 weeks
Hi Tim,
Are the docs ready yet ?
Currently available here: http://our.sandbox.umbraco.org/projects/umbraco-pro/contour/documentation ;
Now also on live env http://our.umbraco.org/projects/umbraco-pro/contour/documentation
http://our.umbraco.org/forum/umbraco-pro/contour/37896-New-documentation-available
