  • Topic author was deleted
    Jan 10, 2013 @ 09:30
    Contour 3.0.6 changes
    Here is an overview of the changes in Contour 3.0.6 which is out today :)
    3.0.6 - January 2013
    Fixed: CON-201 Codefirst, sent to page value on form not being saved
    Fixed: CON-202 Codefirst forms and deploying across multiple environments results in different form GUIDS
    Fixed: CON-200 Conditions and Danish characters
    Fixed: CON-199 Razor macro, submit, next, previous button caption is hardcoded in the view
    Fixed: CON-204 Weird Spacing in between Label and Input Type
    Fixed: CON-198 Very long user-input on textfield throws SQL error
    Fixed: CON-206 Importing form that contains conditions fails
    Fixed: CON-207 Folder entry is still displayed even if user cannot access any of the forms underneath it
    Fixed: CON-173 drop.sql on Manual Installation missing two tables
    Fixed: CON-195 Contour on MVC4 error: 'System.Web.Mvc.HtmlHelper.AntiForgeryToken(string)' is obsolete
    Fixed: CON-208 Not working in medium trust
    Added: CON-197 Form picker datatype, make it possible to disable the create form
    Package and upgrade files can be found on the project page our.umbraco.org/projects/umbraco-pro/contour
    This release should be ready for Umbraco 6.0.0 :)
