When should each of these be used?
Is one for webforms and the other mvc based? or can both be used in any 4.11 setup?
Comment author was deleted
Yup that' correct 1 is webforms (is a usercontrol with webcontrols) that one can be used of you are using masterpages and have a form with runat server attribute
The Razor one is mvc based
FYI... just implemented both versions into a webforms site and they both appear to function... ;-)
Yup the razor one also works on webforms :)
umbracoContour.RenderForm vs umbracoContour.Form
