@if (Model.ContainsValue(pv.Value)){selected="selected"}
should be
@if (Model.ContainsValue(pv.Id)){selected="selected"}
When navigating back to a page the value is not selected when using Value.
Comment author was deleted
Added to our issue tracker, will get updated on next maintenance release, thanks for reporting :)
Here is the link to the issue btw http://issues.umbraco.org/issue/CON-211
Thanks, keep up the good work!
DropDownList.cshtml
@if (Model.ContainsValue(pv.Value)){selected="selected"}should be
@if (Model.ContainsValue(pv.Id)){selected="selected"}When navigating back to a page the value is not selected when using Value.
