We have a project that uses the AjaxControlToolkit. The site worked just fine until we installed Contour. Now we get a .Net error that states AjaxControlToolkit.ToolScriptManager exists in both the .Net 4 Framework and Umbraco.Forms.References.DLL.
We are using Contour version 3.0.1
The actual error:
System.Web.HttpCompileException (0x80004005): c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\99ec0aad\8aaa2fe9\App_Web_editprofile.ascx.6bb32623.lemvzvlm.0.cs(177): error CS0433: The type 'AjaxControlToolkit.ToolkitScriptManager' exists in both 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\99ec0aad\8aaa2fe9\assembly\dl3\169c14f0\8006e9fc_6483cc01\AjaxControlToolkit.DLL' and 'c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\99ec0aad\8aaa2fe9\assembly\dl3\4696fffb\0043b317_4a61cc01\Umbraco.Forms.References.DLL' at System.Web.Compilation.AssemblyBuilder.Compile() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at umbraco.developer.assemblyBrowser.Page_Load(Object sender, EventArgs e)
We are using parts of the AjaxControlToolKit that are not included in the one the included with Umbraco.Forms.References. We are using the AsyncUpload, but when I switch over to using the AjaxControlToolKit from the Umbraco.Forms.References, I get an error that the AsyncUpload isn't found.
Was there ever a good solution for this. We have exactly the same problem and use AjaxControlToolkit extensively for an application. could extern alias be a possible solution? we're in the middle of an upgrade path and this is causing us major issues.
We were basically told to either not use Contour or not use the AjaxControlToolKit...so now we are re-writing our template to not use AjaxControlToolkit.
Contour 3 introduces a mvc powered render form control that doesn't use the ajaxcontroltoolkit so if you use that one you should be able to avoid conflicts
The only option I see is that we remove the use of the ajaxcontroltoolkit out of Contour, I've added this to our issue tracker (http://issues.umbraco.org/issue/CON-291) but no eta on this since I first need to make sure it won't affect upgrades
It happens because just having both AjaxControlToolkit.dll and Umbraco.Forms.References.dll in the bin directory confuses .Net and it is not sure which AjaxControlToolkit.ToolScriptManager to use.
Having the same issues and frankly, this is a really stupid one! No reason I shouldn't be able to install and use AjaxToolKit's full functionality. There must be a fix, isn't there?
I am still also chasing a fix for this after waiting for Contour 3 optimistic that the issue was going to be resolved... I have Installed Contour 3.0.6 on our umbraco 4.9.0 website. Getting Contour working doesn't appear to be an issue though I've only done a basic test, regardless whether you use the MVC macros that don't use Ajax.
The fact that the Umbraco.Forms.References.dll still has a version of the AjaxControlToolkit.dll embedded it causes issues with other areas of our site which use our own version 4 of the AjaxControlToolkit. We've had Umbraco Complete for over 18 months now and are still no closer to being able to use Contour (without it breaking the rest of our site) until there's a viable fix - changing references and other attempts to resolve this from other post suggestions are not providing us with any success.
We do have a custom build available that doesn't have the dependencies bundled up in Umbraco.Forms.References, get you get in touch with me at tg at umbraco dot com and I can provide you access to that build
I am getting a similar error trying to use HtmlAgilityPack HtmlDocument(). It seems like the same issue. Any updates? Can i have access to the build please?
AjaxControlToolKit conflict Contour Forms
The actual error:
Comment author was deleted
When do you get the error? Or is the complete site broken?
The page that is using the AjaxControlToolkit gets a Yellow Screen Of Death with this error.
Ok quick workaround would be to use the razor macro that doesn't use the ajaxcontroltoolkit, not sure if that is an option?
Yeah, not an option for this particular application.
Hmm maybe try using Umbraco.Forms.References instead of adding AjaxControlToolkit, what parts do you need?
Tried that already.
Ok well if that doesn't work I would suggest to go for the razor macro workaround
Nope, no good solution.
Wow. That is very disappointing to pay for something and then not really have a fix.
We ended up adding our assembly to the excluded referenced assemblies in TypeFinder.cs in umbraco.core and recompiling.
Regards,
Tim
Ok, how do I make use of that? We are using Contour 3.
Can I delete the Umbraco.Forms.DLL? Because that is where the conflict is. Even if I don't have a contour form on the page, I get the error.
Nope can't delete that one, so it happens even if you don't have a contour form on the page let me see if we can do something about that
Thanks, that would be great.
Exactly! it happens regardless of having a form on the page or not.
4 months on Tim's issue doesn't like its any nearer to being progressed: http://issues.umbraco.org/issue/CON-291
Anyone managed to find a solution?
Thanks in advance.
Hey Marie,
I'll look into making this part of our build process so it's available on the nightly build server but for now please contact me if you want access
@Umair can you mail tg at umbraco dot com and I'll provide you with access to the custom build :)
New build coming soon that won't have ajaxcontroltoolkit so no more conflicts, you can already get it here http://nightly.umbraco.org/Umbraco%20Contour/3.0.18/
