  • SC Digital Services Team 104 posts 171 karma points
    Jan 17, 2013 @ 12:58
    Umbraco exception when using checkbox lists
    We are using Contour 3.0.6 on Umbraco 4.9.0 and have come across a strange bug when using CheckBoxList fields in our forms. The problem only occurs when more than one checkbox is selected, which causes the following error when the form is submitted:
    "Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery"
    Looking into the logs it seems to be a similar error as reported in this issue - http://issues.umbraco.org/issue/CON-118
  • Comment author was deleted
    Jan 17, 2013 @ 13:09
    Could it be that the Contour version was upgraded from an earlier v3 version? That reintroduces the following bug http://issues.umbraco.org/issue/CON-98 (due to a bad merge)
    To fix on your install simly run the following sql script
    ALTER TABLE UFRecordDataString
    DROP CONSTRAINT PK_UFRecordDataString
    GO
    Jan 17, 2013 @ 13:15
    Yes it was an upgraded version of Contour & your script has worked a treat - thanks Tim!  #h5yr
