Is there up-to-date developer documentation for Contour 3? The contour page here says the Developer Documentation is "Is available below as a pdf." but that file is for version 1.1.9 and is over a year-and-a-half old. Thanks in advance for your help.
Contour 3 Developer Documentation?
Comment author was deleted
Hi Joshua,
The pdf doc is still valid it's just missing some new stuff, we are working on new docs here https://github.com/umbraco/UmbracoContourDocs
Most of the new stuff in v3 of Contour has been documented on my blog which you can find here http://www.nibble.be/
While waiting for the new docs feel free to ask questions on the forum, I'll do my best to answer then :)
The github link (from Tim) has 404s for some of the documentation (all the "Create a form" stuff for example, and Custom Markup).
You can find the documentation here: http://our.umbraco.org/projects/umbraco-pro/contour/documentation
