  • MK 429 posts 906 karma points
    Jan 23, 2013 @ 10:51
    MK
    Contour member tools compatible with umbraco 4.11.1?
    Hi there,
    Is Contour member tools compatible with umbraco 4.11.1?
    thanks
    mkariti
  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 23, 2013 @ 11:06
    Fuji Kusaka
    Not sure if member tools is compatible but one thing  we can be sure of is the latest version of contour from the videos we saw is a complete blast and more flexible.
    Havent tried it yet but you should be able to use it for members section as well.
  • Comment author was deleted
    Jan 24, 2013 @ 08:20
    Yup don't see why it shouldn't work with 4.11.1
    Jan 24, 2013 @ 09:07
    There is also an example of using code first and creating member login/registration/profile/change password http://www.nibble.be/?p=205
    Feb 05, 2013 @ 14:55
    MK
    Hi Tim,
    Ok so Im trying to implement the code first for Login form but with no success.
    I modified the following form as I need to use user name and not Email addess for login:
     [Form("Member/Login", ShowValidationSummary = true, MessageOnSubmit = "You are now logged in")]
        public class Login : FormBase
            [Field("Login", "",
               Mandatory = true)]
            public string Name { get; set; }
            [Field("Login", "",
                Type = typeof(Password),
                Mandatory = true)]
            public string Password { get; set; }
            public override IEnumerableValidate()
                var e = new List();
                if(Member.GetMemberFromLoginName(Name) == null)
                    e.Add(new Exception("No member found with this Name"));
                else if (Member.GetMemberFromLoginNameAndPassword(Name, Password) == null)
                    e.Add(new Exception("Incorrect password"));
                return e;
       public override void Submit()
                var m = Member.GetMemberFromLoginNameAndPassword(Name, Password);
                if (m != null)
                    Member.AddMemberToCache(m);
    Now It created anothe folder in Contour called Member and with a form child called Login.
    This seems to do nothing and I cant debug it as well.
    Also, I cannot delete this form or its parent folder.
    Any Idea?
    mkariti
    Feb 05, 2013 @ 14:59
    Are you outputting the form with the razor macro?
    Feb 05, 2013 @ 15:00
    MK
    Nop. control.
    Feb 05, 2013 @ 15:06
    yeah it's only supported by the razor one, the usercontrol one is getting obsolete
    Feb 05, 2013 @ 15:07
    MK
    Ok I tried the razor and its only add to entry with no login.
    Ive also managed to delete it.
    Feb 05, 2013 @ 15:09
    MK
    Also, I would prefer not to add it to entries as It reveal the psw
    Feb 05, 2013 @ 15:41
    MK
    Not sure what just happened but I changed the class from Class library to Internal class and it works!
    Many thanks
    mkariti
