  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Jan 25, 2013 @ 10:20
    Tim
    Long field names cause the Razor Form Rendering Macro to fail
    Hiya,
    I've spotted an issue that if you have a long field caption, you get an error stating that the file path is too long, must be betweeen xx and xx characters and the form doesn't render, when using the Razor rendering macro. If you switch to the webforms rendering macro, it works fine. This is using the latest version of Contour from the nightlies.
    I've debugged as much as I can, and it looks like the call to @Html.Partial(FieldViewResolver.GetFieldView(Model.FormId, f.FieldTypeName, f.Caption), f) in the rendering macro is the culprit, specifically the FieldViewResolver I think. I guess it's creating some kind of MVC style path based on the field caption maybe?
    Can this be fixed? As a workaround, we're using the webforms renderer, but we'd ideally like to use the Razor one so that we can control the markup.
  • Comment author was deleted
    Jan 25, 2013 @ 10:34
    Thanks for reporting, will look into it
    Jan 25, 2013 @ 12:09
    Looking into it now, added issue to the tracker http://issues.umbraco.org/issue/CON-224
    Jan 25, 2013 @ 12:18
    Fixed in 3.0.7 WIP, if you download the upgrade http://nightly.umbraco.org/Umbraco%20Contour/3.0.7%20WIP/ archive and you'll just need to update the umbraco.forms.mvc assembly to make it work
    Jan 25, 2013 @ 12:24
    Tim
    Nice one, thanks Tim, that was super fast :)
