Any news on this. We are preparing to take 6 into production, but compatibility of pro packages is essential. I see a slight flaw in the roadmap there ;-)
Go to the Courier section in the forums for more information, you'll find a few of my rants at Per in there, it will give you a better idea of what's involved!
By all accounts Tim is able to react quicker to changes in the Core of Umbraco as his project isnt as closely tied to the core as Courier is. It's a bit of a pain but bear this in mind when planning deployments.
Also I would argue Contour is more stable than Courier is currently. Courier has improved rapidly since version 2.7, but it still has a few issues you should be aware of as it may affect your own plans.
Overall i've found Umbraco v4.11.4 and v6.0 to be stable, while v6.0 remains surprisingly compatible with the majority of extensions that have been designed for Umbraco 4.7 and higher..
Pro packages under V6x
Will the current Pro packeages work under v6?
Melvin
Comment author was deleted
Contour works (from version 3.0.6, latest stable at this point) the other 2 don't at this point
thanks for the quick reply! Is there a plan for the other 2? ;-) We have all systems ready for v6 to go in production...
Thanks a bunch!
I know Courier is in progress but no idea of an eta
Hi Tim,
Melvin
Hey Melvin
Martin.
