  • Richard Barg 358 posts 532 karma points
    Jan 31, 2013 @ 01:34
    Richard Barg
    Leveraging Conditional Logic on a Form to Drive Custom Workflows
    Is is possible via a custom workflow work with conditional logic of form area.
    Here is an example:
    • User checks Dept. A checkbox on form -> Workflow posts "saves as Umbraco document" record to Node A in Umbraco content tree.
    • User checks Dept. B checkbox on form-> Workflow posts "saves as Umbraco document" record to Node A in Umbraco content tree?
    In the example below, I am creating a separate Umbraco form for each lab to post a publication.  It would be ideal to have one form and have checkboxes corresponent to our 20 labs. The workflow would then save the Contour form results to the Umbraco node associated w/the lab.  Can this be done in a custom workflow with Contour 3?
  • Comment author was deleted
    Jan 31, 2013 @ 09:14
    Might work with the default save as umbraco document workflow, enter an xpath the setup the parent location and use the value to look for the node based on the name (using the bracket syntax to easily fetcth the value)
    Jan 31, 2013 @ 19:10
    Richard Barg
    Thanks Tim. Here is a related question.   Would it be possible, using the above workflow or a variation of it, to save the document to multiple locations in tree.  For example, if we wanted to add a publication, see screenshot below, to more than one node on a single pass, ie the Publications page on several websites w/in the Umbraco tree, after the form is submitted.
    Feb 01, 2013 @ 08:39
    Sure but you'll need to customize the workflow for that
    Sourcecode for the default providers is available on the project page http://our.umbraco.org/projects/umbraco-pro/contour
    Or here is a direct link :) http://our.umbraco.org/FileDownload?id=2922
