  • Martin Griffiths 826 posts 1269 karma points c-trib
    Feb 01, 2013 @ 16:55
    Martin Griffiths
    Woooaaah Contour and Umbraco 6 fun!
    Hi Tim
    I expect you're mid flow testing Contour in Umbraco 6, but my forms no longer run, with this rather serious looking error...
    'Operation could destabilize the runtime'.
    Martin
  • Comment author was deleted
    Feb 01, 2013 @ 20:07
    Oh my haven't seen that before, is that an install you upgraded?
    Feb 03, 2013 @ 11:04
    Martin Griffiths
    Hi Tim
    yes thats an upgrade
    Feb 04, 2013 @ 08:31
    Ok will see if I can reproduce
  • sun 403 posts 395 karma points
    Feb 04, 2013 @ 08:46
    sun
    I hope 3.0.7 can be installed with Umbraco 6. When will it be released?
    Feb 04, 2013 @ 09:12
    Martin Griffiths
    Hi Tim
    I've just tried previewing my CodeFirst Forms and they fail in the same way. Would you like my code for testing?
    Martin
    Feb 04, 2013 @ 09:33
    @Sun 3.0.7 is coming today
    @Martin no not needed should be able to reproduce
    Feb 04, 2013 @ 11:00
    Martin Griffiths
    Hi Tim
    Sorry to be a pain but the object reference error has come back again (since upgrading to 6)
       Umbraco.Forms.Data.Storage.PrevalueSourceStorage.GetAllPrevalueSources() +61
       Umbraco.Forms.CodeFirst.PrevalueSourceManager.SynchronizePrevalueSource(Type typePrevalueSource) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\PrevalueSourceBuilder\PrevalueSourceManager.cs:36
       Umbraco.Forms.CodeFirst.PrevalueSourceManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\PrevalueSourceBuilder\PrevalueSourceManager.cs:22
       Umbraco.Forms.CodeFirst.UmbracoManager.Synchronize() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:33
       Umbraco.Forms.CodeFirst.UmbracoManager.SynchronizeIfNotSynchronized() in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\UmbracoManager.cs:21
       Umbraco.Forms.CodeFirst.ContourFormBuilderHttpModule.context_BeginRequest(Object sender, EventArgs e) in c:\Program Files (x86)\teamcity\buildAgent\work\fdc2f0fcbbcef310\Umbraco.Forms.CodeFirst\ContourFormBuilderHttpModule.cs:27
       System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
    Feb 04, 2013 @ 13:12
    Feb 04, 2013 @ 15:41
    Martin Griffiths
    Hi Tim
    I've just downloaded it, checking it out now.
    Martin
    Feb 04, 2013 @ 17:16
    Martin Griffiths
    Hi Tim
    I've only done enough testing to see if the site comes back up, no more "destabilize" error. :-)
    I did get the reference error again, but I think it was down to some tweaks needed in the web.config.
    So far looking good!
    Martin
