  • David 32 posts 52 karma points
    Feb 04, 2013 @ 15:57
    David
    Contour templates Id problem
    It seems whenever I generate a template from a form I am only allowed to use that template once to create a new form because the Id is a primary key in the UFForms table.
    Is this expected behaviour?
  • Comment author was deleted
    Feb 04, 2013 @ 17:47
    Feb 05, 2013 @ 11:16
    David
    Not using Umbraco 6 however. . .
    Feb 05, 2013 @ 11:30
    download the upgrade archive and deploy the umbraco.forms.ui.dll that should take care of it
    and the umbraco.forms.core one
    Feb 05, 2013 @ 12:14
    David
    Not following exactly I don't think.  Do you mean 3.0.6 update in the archive section of http://our.umbraco.org/projects/umbraco-pro/contour?
    In which case I have tried but am getting the System>web.WebPages.Razor issue.  Obviously because of MVC3 vs MVC4?
