  • Gísli Freyr Svavarsson 43 posts 126 karma points
    Feb 05, 2013 @ 16:38
    Contour 3.0.6 on umbraco 4.8 installation problem
    Hi there folks
    i'm having trouble installing contour 3.0.6 on an umbraco 4.8 site.
    i get the following error: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_umbracoUser2app_umbracoApp"
    does anybody know what might be the problem?
    mvh
  • Comment author was deleted
    Feb 05, 2013 @ 16:40
    Might be that the section wasn't added in the db correclty and it's now failing to give a user access... do you have direct access to the db?
    Feb 05, 2013 @ 16:41
    If so check if you can see tables prefixed with UF and if you see a contour section in the umbracoapp table
