In all the examples I can find the value for this parameter is NoIndicator. What do I write there if I want it to be "Mark mandatory fields only". I've tried some combinations like "MarkMandatoryFieldsOnly" and "MarkMandatoryFields" but these are wrong.
Like mentoined in the previous reply, just create the form you want and then export that, you will then end up with an .ucf file that can be used as a template...
Possible values for FieldIndicationType in Contour template?
I'm creating my own Contour template (.ucf-file) and there is a parameter called FieldIndicationType:
/Thomas
Comment author was deleted
Tim
Thanks Tim!
Just to clarify if someone comes along later searching for an answer to this question, Tim is referring to this post.
/Thomas
