  • Paul Fowles 75 posts 184 karma points
    Feb 12, 2013 @ 16:52
    Paul Fowles
    Contour rollback - will it cause any problems?
    Hi Tim,
    I've tried using contour 3.7 with umb 4.11 and realised it doesn't work when I previewed a form I was working on so I've rolled back to the 3.6 update and copied the relevant files over as I had already written a number of forms. It seems to work without a loss of forms. Do you see any issues with this solution?
    Regards
    Paul Fowles
  • Comment author was deleted
    Feb 12, 2013 @ 17:04
    Nope should work fine :)
    Feb 12, 2013 @ 17:55
    Paul Fowles
    Ok thanks for that!
