  • Carlos 338 posts 472 karma points
    Feb 13, 2013 @ 22:02
    Carlos
    Umbraco 4.9.1 and Contour 3.0.6 form won't save
    We had Contour 1.1.4 installed on our version of Umbraco from a ways back. We have since upgrade Umbraco a few times but did not use Contour since then.  We are now on Umbraco 4.9.1 and just happened to look at the Contour version.  So I uninstalled Contour 1.1.4, installed 3.0.6 and the interface came back that was not there when 1.1.4 was installed.  I tried to save a simple test form just by creating a new form, added a multi option and then tried to click the save button. Got the "Form Not Saved" pop up. Is there anything I need to do?  Or a file that might not have been updated?
    Although I don't quite get it because the forms are showing up in my list under "Forms" in Contour.  I am baffled. Are they actually saving or not?
  • Comment author was deleted
    Feb 14, 2013 @ 09:16
    Might be because the js is cached, could you try clearing your browser cache
