I got a problem with Contour, it does not render on my umbraco site.
Running Contour 3.0.7.0 and Umbraco 6.0 with MVC razor. The only information I get is this: Filtering is not allowed.
Is there something I have missed?
Comment author was deleted
@Roberto and does the form show up when you preview it?
It works in preview. Well in Contour not on the Node
Sounds like it might be an issue on your template then, are you using views or masterpages?
Using Views.@inherits Umbraco.Web.Mvc.UmbracoTemplatePage@{ Layout = "~/Views/Contents.cshtml";}@Umbraco.RenderMacro("umbracoContour.RazorRenderForm", new {FormGuid = "36b6ff68-0afa-4c5d-8784-1ebb36e04dd4"})
Ok let me see if I can reproduce
Just tried the same setup and it works so it's most likely an issue on your views...
Could you try if it works with the most basic template (just create a new test)
@inherits Umbraco.Web.Mvc.UmbracoTemplatePage @{ Layout = null; } <html> <head> </head> <body> @Umbraco.RenderMacro("umbracoContour.RazorRenderForm", new {FormGuid="128862f6-df30-43f4-abaf-21ddf8107725" }) </body> </html>
(just need to change to correct formguid)
Still the same error. Can it be a config issue on the web.config?
Did you customize the views of the contour form?
Do you mean MvcRenderContourForm.cshtml? Then no.
I tried the exampel you posted.
Strange, any chance I can take a look at the installation, you can mail details to tg at umbraco dot com
Contour not rendering
Using Views.
@inherits Umbraco.Web.Mvc.UmbracoTemplatePage @{ Layout = null; } <html> <head> </head> <body> @Umbraco.RenderMacro("umbracoContour.RazorRenderForm", new {FormGuid="128862f6-df30-43f4-abaf-21ddf8107725" }) </body> </html>(just need to change to correct formguid)
